Field-bus network MAX-OUT challenge
jdbrandt
Oct 2002
Pennsylvania
1,203
OK, for fun (only), I've had a recent curiosity as to any fieldbus network MAX-OUTs that people on here might have actually made work.
Replies should be:
NETWORK: (example: Data Highway Plus)
Engineering Limit (number of assigned nodes/stations): (example: 64)
Design Limit (allowing for 0-node, or recommended reserve nodes) : (example 62)
Actually implemented and working in a real world environment: ( <???> )
Lets see what comes in....no lying (!)
Replies should be:
This is a REAL application, in a REAL place.
NETWORK: Ethernet/IP
Engineering Limit: none
Design Limit : 300 connections - 1756-L85 processor
224 PowerFlex 525 VFD
8 third-party fieldbus gateways
8 third-party fieldbus (different from above) gateways
8 managed switches in Ethernet/IP enabled.
I didnt answer before since our projects are not that big.
These are the "biggest" I have experienced:
NETWORK: Profibus DP
Engineering Limit: 32 stations per segment. 126 stations per network.
Design Limit : 126 stations.
10 ET200 stations + 3 MM4 VFDs + 1 Operator panel
NETWORK: Profinet
Engineering Limit: 256 stations per network. (edit: actually I am not sure if that is just the limitation of the CPU, not the theroretical maximum)
Design Limit : 256 stations.
16 ET200SP stations + 5 G120 VFDs + 4 operator panels (in the network but not as Profinet devices)
Hi, I just experienced something strange. I connected a Field PG (PG/PC adress 0) on a profibus network to monitor something in the field. I...
6,852
Looking for a LIDAR sensor (2d) that we can use with a Siemens PLC for measurement, Would like to interface directly with 4-20mA or a Field bus...
980
Hi all this is bit ot but here goes.. What kinda fieldbus you use / would use if youre going to build new installations on youre process.. Is...
24
4,345
My attempt to communicate with Foundation Fieldbus transmitters with Pactware and a new, out-of-the-box Softing FF modem are a disaster - failure...
17
5,036
For whatever reason, I've always been a "sensor straight to the cabinet" kind of guy. It "just works", it's easy to troubleshoot, you never have...
7,156
