blueyedpeter
The point i was trying to make was that having executed each of or any sequence , timer control or staging , a delay timer on each stage could stop the rung from completing totally and allows for a 3 or 4 second change over to the next room to start . A single control rung could prevent the pump from being used on any more than one room at a time .
But stacking would allow the order to be maintained , on the other hand the timers would be random and would allow shorter program timers to come to the front and obvious longer timers to start last .
If total control over spray length and order of operation if required , then your fifo stack would allow for a greater level of predictability . otherwise creating or organizing maximum through put of the rooms would be difficult .Indicators indicating rooms in waiting would do just that but no more , and not give you an idea to an up coming event or process order .The fifo answer is probably your best but i haven't worked here yet .
Timers would be random but would lack a level of predictable and complete control but you cant shorten a distance between two points any shorter than a straight line . on any given day process time will need to be organised to help with the through put of the rooms . I suggested a small model of the fifo action not for counting but to bring up an output in an orderly fashion any how good luck.
