FIFO function block in CoDeSys 2.3
MaReKA
Nov 2015
KA
75
As I'm just in the flow of typing along (have to get a new backspace key soon)...
I tried to write a function block in CoDeSys that what somewhat behave like the ones I use in RSLogix every other day - Didn't turn out well and this might turn into a rant :(
Writing the basic functionality for a fixed lenght array of a data type that is defined in the function block was easy, but in RSLogix I can feed the FFL & FFU with an array of every data type know to man (+UDTs) that can be as long as the controller memory can make it.
I remembered using pointers during my last exposure to Step 7 programming in technical college. I looked into the laughable helpfile that is supplied with the software and spent some time on google. I came up with something that can handle an array of variable length for a data type that fits in a DWORD. Thats nice, and probably as far as I will take it now.
I asked in a german forum if there is another way to do it, or a way to use this function with a UDT without having to rewrite the funtions defintion each time I wanted to use another UDT. I wanted to abstract the function as much as possible.
The answer was that pointers are not defined in IEC 61131-3 and are a general No-No and should be used only if absolutely needed. Also the implementation is not mandatory for different CoDeSys packages.
Basically that answer is fine for me, the problem is not solvable within the technical boundarys of CoDeSys - or is it? Maybe some of you folks here know a way to do it :)
What I personally took from it is the knowledge that I have to thank my boss for every buck he pays for RSLogix licenses. Working 10+ years with RSLogix I tend to find Step 7 and CoDeSys really clumsy to work with, its a trip into history, '98 when I first used Step 7 after using a field programmer on a Kloeckner-Moeller PS3 before... Something like the strong binding to data types (when I want to COP a REAL into a DINT and create a mess its my problem, isn't it?) makes me think about what Rockwell is doing different, and for my part better.
Done. Delete if unsuitable ;)
Maybe I should add some code:
Code:
[SIZE="1"]FUNCTION_BLOCK FIFO
VAR_INPUT
 LoadValue:   POINTER TO DWORD;
 UnloadValue:   POINTER TO DWORD;
 FirstElement:  POINTER TO DWORD;
END_VAR
VAR
 i:      INT;
 DestPointer:  POINTER TO DWORD;
 SourcePointer:  POINTER TO DWORD;
END_VAR
VAR_IN_OUT
 Ctrl: ST_CTRL;
END_VAR
Size :=  SIZEOF(FirstElement^);
IF Ctrl.Full AND Ctrl.Autounload AND Ctrl.Load THEN
 SourcePointer := FirstElement + ((Ctrl.Position - 1) * Size);
 UnloadValue^ := SourcePointer^;
 Ctrl.Position := Ctrl.Position - 1;
END_IF;
IF Ctrl.Load AND (Ctrl.Position < Ctrl.Length) THEN
 Ctrl.Done := FALSE;
 FOR i := (Ctrl.Position) TO 1  BY -1 DO
  DestPointer := FirstElement + (i * Size);
  SourcePointer := FirstElement + ((i-1) * Size);
  DestPointer^ := SourcePointer^;
 END_FOR;
 FirstElement^ := LoadValue^;
 Ctrl.Position := Ctrl.Position + 1;
 Ctrl.Done := TRUE;
END_IF;
IF Ctrl.Unload AND (Ctrl.Position > 0) THEN
 Ctrl.Done := FALSE;
 SourcePointer^ := 0;
 Ctrl.Done := TRUE;
END_IF;
IF Ctrl.Position = 0 THEN
 Ctrl.Empty := TRUE;
ELSE
 Ctrl.Empty := FALSE;
END_IF;
IF Ctrl.Position < Ctrl.Length THEN
 Ctrl.Full := FALSE;
ELSE
 Ctrl.Full := TRUE;
END_IF;
[/SIZE]
Anyone know of an easy way to program a FIFO in function block for RSLOGIX500. There appears to be no instruction for this. I'm sure I can put...
2,812
Hi all, I am playing around with omron at the moment. I have a CJ1M CPU22 plc and cx programmer version 9.4 to test with. Currently i am working...
5,830
Hello! I have a network of conveyors bringing raw product to 4 machines. A sensor in the hopper of each machine calls for more product. I'm...
5,886
hi guys, really need your help again.. i find it difficult not familiar with Omron software while my project schedule is so tight! I would like...
12,511
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
226
