Figure Out Which Input Shut Off First
Not sure if this is an option outside of Rockwell, but one of the simplest ways to do this without any extra programming is simply to trend the inputs.
Trending is a possible option, however, some PLC's do not have it, The OP is using an HMI but assuming one input (presumably a conveyor in this case) then the others shut off as well according to the OP, this means it could happen quite quickly, The HMI would probably not pick it up due to coms latency, or the amount of memory required to store a very fast trand of say 10 inputs for enough time for a check on what was switched off would probably exeed the memory capacity, so in reality, probably not a practical option. I also believe that there is possibly an idea to have an indicator on each conveyor or what ever showing which one was stopped first.
Hi @JeremyM:
I recalled having told you that when importing your new library for Logix I got some problems, I do not what happened but I have no problem now I did not change anything.
Thank you very much indeed for your efforts, just one question when help is going to be available or was I looking up on the wrong side. ? God bless you.
Hi @JeremyM:
You can PM me with any questions. I'm happy to help.
Once I get a major project of a block out of the way, I'm circling back to cover more of the Wiki with deeper documentation and how-to stuff.
Been trying to work on having multiple data types in a input/output assembly similar to have a powerflex has bools for most then an INT for the...
19
7,846
Good Evening , I have a 1756-IF16 Analog Input card already installed in a working ControlLogix Rack. I need to add another Analog 4-20 ma...
2,184
Good Afternoon , Powerflex 753 seems confusing just to configure a input. A coworker installed a pushbutton to use as a fault reset for a...
3,999
I have installed 1769 IF4 analog input module in compact logix rack slot 3. I have an existing 1769 8 channel input card in slot 2 already...
2,444
I have CLX 5561 that has some inputs that are dropping out and I cant figure out why. I have a counter to catch them dropping out and also a timer...
19
6,172
