How to configure eds file for multiple data types in input/output assembly
Make sure you understand the implications of using INT instead of SINT. For example, if your data is coming over 2 SINTs (Or 4 SINTs) and is byte-swapped then you are going to get the wrong value by trying to process the single INT. Another good example is a device that has mixed data of 8-bit, 16-bit and 32-bit types, where using INT may cross the boundary of different words of data (Again resulting in the wrong value). I guess the third example is if your device is presenting ASCII charaters as SINTs like a barcode scanner or vision system result. ASCII is better to process as a SINT array, as each character is represented individually.
If your device is providing all data as 16-bit words then INT shouldn't produce these issues.
You will have to be offline then change it and re-download. Can't do it online.
Thanks for the replies, but I am not asking about how to use the EDS, I am trying to alter the EDS so that the default data type for the user to select defaults to the INT selection instead of SINT by default. Is that even possible?
Misunderstood, sorry. You'll find Data Type and Data Size in the Params section of the EDS. INT is 2 bytes of type C3. You may want to save your edited EDS as a different name and version to import. You can also get programs like EZ-EDS that will allow you to make/edit EDS files.
Code:
        Param3 =
                0,                      $ reserved, shall equal 0
                ,,                      $ Link Path Size, Link Path
                0x0000,                 $ Descriptor
                0xC8,                   $ Data Type
                4,                      $ Data Size in bytes
                "RPI Range",            $ name
                "",                     $ units
                "",                     $ help string
                2000,3200000,10000,     $ min, max, default data values
                ,,,,                    $ mult, div, base, offset scaling
                ,,,,                    $ mult, div, base, offset links
                ;                       $ decimal places
Code:
        Param3 =
                0xC8,                   $ Data Type
                "RPI Range",            $ name
                "",                     $ units
                "",                     $ help string
                ;                       $ decimal places
Thanks, I have been using the OVEDA software, but it looks like you can only assign a parameter to the T->O and O->T size that is defined as a UINT.
Did you happen to figure this out? I'm having the same problem.
I should also add that it would be nice if there was a way to have EDS parameter names or help strings appear in the controller tag descriptions so that the user could know the description of each INT.
I`m trying to command a Mitsubishi inverter F800 using a Micrologix PLC with message instructions. I sucessfully controled it using a Compact...
3,294
Hello. Have been struggling the best part of today with this one issue that I try to explain with the screenshot below. As I show from the EDS...
3,296
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
163
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
240
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
152
