Finding tags for FactoryTalk SE
PLC5Please
Aug 2014
BC
Howdy all. Should be an easy one but im pulling out my hairs here.
I have a motor i want to start with a button on the factorytalk screen. Now this is a new tag that isn't in the HMI Tags/Tags folder. All I want is to see this new tag. I have been reading and reading about it and am having no luck. I want to either add it to the tags or just see the tags in the controller. (RSLogix5000). Now everything i read says dont import tags just use them from the offline PLC file. This is where im hitting a brick wall. How do I see these tags from the file?
Here's a copy of advice from plc.net
You don't have to import tags like this way.
In the communication-setup tab, you can point FT view to the off-line RSLogix5000 program file.
Where is this communication-setup tab. I have the offline file but I dont know where to set it up to be viewed. YAARRGG.
Thanks for any help, much appreciated.
Wow if only I waited 2 more seconds.....I found the communication setup. Ok so it is pointing to and old ACD file. I want to use a new one. If I change the file to the new one will I run into any scary issues? Or will it be happy. There wont be any tags taken out of the new file just a handful of new ones.
Well I think i've found a happy medium here. I left the old ACD file in and added the controller itself to the list. Now I go to tag browser and there is a folder with the offline tags and a folder with online tags. Think this will solve my issue.
Hello all, I have what has become a complex problem, with what I'm hoping is a simple answer. I am using FactoryTalk Linx Gateway set up as an...
2,395
Hi all, I figured out how to get my runtime app on my computer to point to the right PLC, but now I am getting a diagnostic error: Item Known to...
3,411
Hello, I have an array of 300 of UDT. In each UDT is an array of 3 DINT and another array of 3 REAL. I have 10 controllers that pull data from...
1,179
All, I am going through an existing HMI program that has about 900 tags. I am pretty sure there are multiple tag names referencing the same tag...
2,202
Hi all, I have been using RSLogix for the last couple of months and one thing I miss coming from Schneider Unity Pro is the ability to find tags...
3,810
