Gents,
As I was monitoring drive 2 which has the motor connected, I didn't see the E35 fault on the IAM.
So I checked the Output voltage of the LIM which is 3 phase 400 volt, which seems to be right. The measured bus voltage is 603 volt...
I've connected to motor to drive 1 which is the IAM.
When I apply power to the system, I see all the drive walk to there seq. 1..2.. drive 1 goes to 3..4 the LIM switches the main power on, and off again. Followed by the E35 message on the IAM.
Search trough some documents, I found the earth jumper, and found out it was set at 230 volt. as it is a 400 volt system, I've modified the setting of this jumper, with no result.
Note: the system has worked for years with this wrong jumper setting. And before the firmware update I could run the motor with no errors on the drives.
Has anyone an idea what's happening here?
Thanks in advance!
Jack
