First Scan Bit in ControlLogix
dcooper33
Jun 2011
Rogers, AR
717
Hi guys,
I've got a basic question about how the "S:FS" bit is handled in CLX processors.
I'm wanting to trigger some anti-diameter reset logic on power-ups on an unwind stand which is controlled by an L61 processor.
The routine where the diameter reset is controlled is in a periodic task which runs every 30ms. What I'm unsure about is if the processor will scan every routine on the first scan, or only the continuous ones. Therefore would an XIC S:FS instruction evaluate false by the time my periodic task is called?
If this is the case, then I can do something like this instead:
Code:
SOR BST XIO Always_True_Unwind_1 OTE First_Scan_Unwind
NXB OTE Always_True_Unwind_1 BND EOR
I'd prefer to use the S:FS bit if possible, it's less rungs, and cleaner in my opinion. I've got quite a few machines that I need to roll this out on. Anybody test this one out before?
Thanks, guys.
Cheers,
Dustin
That is an interesting question to which I do not know the correct answer.
If you have a main task which is continuous, you could latch an internal global bit:
XIC S:FS OTL My1stScanBit
And, then only unlatch it after your last usage of said bit in the periodic task. If more than one periodic task may need access, you may want to latch a unique bit for each of them to be certain that they each have proof that a first scan took place.
Using the OTL rather than sealing in the OTE will remove the need for branches making it only slightly simpler than what (i think) you have coded above. I expect one of the Logix gurus will come along and provide a definitive answer, for all of us, pertaining to the root question.
When I monitor a N/C bit addressed to the S:FS bit in RSLogix5000 online, I expect it to be "green" indicating power flow to the right, but it...
17,492
Hello. Does anyone know the equivalent of the first scan bit in a L32ER compactlogix? Do o need to obtain it via GSV? I’m looking to regain...
460
I want to know how to make a flip flop rung that will change states every scan. This is for a fast sequencer. Is there a special bit similar to a...
2,191
Dear Sir, Can you please tell me how to use the first scan bit, S2:1/15 in RsLogix 500 to Prevents the latch output to be ON when the power...
22
10,273
hello all, I am trying to set up a latch bit like this S:FS----- true condition------OTL. I tried in rs emulator and it the bit latches but in...
1,848
