Fisrt time doing plc ONC
Lindsey
Nov 2004
Wales
hi its my first time to this site finding it very helpfull and learning a lot. Can anyone explain the plcs storage, scanning, memory and its continuous updating to me Thanks.
Welcome Lindsey,
Congratulations on being the first ONC poster, we have had plenty of HNC posters but you are the first ONC one.
You will normally get told to do the research yourself, then, if there is something you don't understand, post what you do know and others will help you out.
Have a look at this site. Click Here , look at the EdExcel prog. logic controller section, that could possibly answer your question, this is the HNC syllabus, not ONC, but it might help anyway.
You can then post any specific questions, but be warned, lazy students are quickly shot down in flames.
A good book to get hold of, from your college library maybe, is Programmable logic controllers by W Bolton. That book will provide you with all the answers necesary.
Paul
P.S To my American friends, the ONC is the certificate taken before the infamous HNC.
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
193
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
511
In Easy Builder Pro: Unexpected results... I've got a toggle switch set to trigger a macro to write a specified integer or a 0 depending on the...
2,317
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,824
Is K4M101 a constant? Is K7 a constant? What does this instruction do? Thanks
19
5,105
