fix32 database import/ export from CLX
Jun 2005
54
Hi friends,
I am working on fix32 with CLX processor first time. As rslogix supports csv format for tag edit, I want to import tags from CSV file into SCADA (fix32 7.0). Is it possible to import it in FIX32?
Actually it supports import export in gdb format. Can anyone tell me how to edit it in excel or .csv format.
Thanks in advance.
Pramod.
I'm pretty sure that it's possible, though I've never actually done it myself. Once you have it open in excel you can make any changes or additions you like by opening the csv file in excel.
Thanks Russ.
But is there any way to open a .gdb file in csv format and in the reverse way? (one like rsview32 exported tag file.)
Pramod.
Pramod.
You need to get hold of an old third party utility called GDB_Make. This will allow you to convert GDB files to CSV and back again. It works very well but there are still some pitfalls when you edit the files in Excel because Excel tries to format cells automatically. The most common problem is that a Fix tag name extended to bit level tends to be interpreted as a time value by Excel and this can be difficult to get round. I doubt whether GDB_Make is still commercially available but someone might have a copy you can download.
Andybr
I have a project using a customers existing Fix32 platform. I have to convert the tags from PLC5 to Controllogix. I am trying to get up to...
3,074
Hi guys. I have a problem regarding remote node database. There is a remote node and its datbase available in PDB folder with node name as name...
6,065
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,300
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,069
I was introduced to Intellution Fix32 scada software at one of my customers today. They have no support from the programmer that built this setup...
5,985
