Fix32 v6.15 Default/Master Password
JElder
Apr 2011
Aberdeen
23
Having just re-installed Fix32 v6.15 for a client and replaced the Fix32 directory with their backups containing all their configuration files/applications, I'm having difficulty logging in.
The client also doesn't remember any of their passwords.
I seem to remember hearing there was a default override password for situations such as this "MASTER" or something similar?
If I remember correctly you can opt out of the security when restoring a project, however I believe that it only gives limited access but maybe you could then configure the security again, I'm not sure but there is also a way of deleting some files etc. but again this only gives some access but maybe someone else knows this back door or you could google it & see if this comes up with a way.
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,297
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,066
I was introduced to Intellution Fix32 scada software at one of my customers today. They have no support from the programmer that built this setup...
5,968
Hello all, I'm using Fix32 7.0 and I would like to communicate with an OPC server. As I understand I need to install an OPC client driver? Where...
3,441
Hi All. I have an old Windows NT machine that has FIX32 running on it. I've added a network adapter to the computer and now Fix32 Startup is...
1,479
