bigbuckaroo
I have recently installed one of these counter modules into an exisiting working Flex I/O system. The goal is to read pulse inputs from an Anderson Insturments IZMAG flow meter. IZMAG instruction manual here: http://www.andinst.com/PDFs/2070.pdf. Here is the installation and startup guide: http://www.andinst.com/PDFs/1175.pdf. The manual for the Flex module is here: http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1794-um016_-en-p.pdf. The manual for the IP4 has examples for configuration using BTR and BTW instructions via Controlnet etc. This is on an Ethernet IP network and a Tech note with an example program is here: http://rockwellautomation.custhelp.com/app/answers/detail/a_id/26592. Tech Connect required I believe. So now I am confused and looking for minimum configuration needed for the IP4 and the IZMAG to read flow pulse inputs. I have the IZMAG set to mode 5 which is 2 independant pulse outputs 1 for each direction of flow. Forward flow output is Pulse output 1 where terminal 25 is the - signal and terminal 26 is +. I have terminal 25 of the IZMAG wired to the IP4 module ussing a TB3 base and it goes to terminal 17. Terminal 26 of the IZMAG is wired to terminal 0 of the IP4. The IP4 is powered and no faults, it is showing as running in RSLOGIX 5000 I/O tree. I have had flow through the flow meter as confirmed by the on board display. Can somone take a look at the manuals I provided and see what the heck I need to do to get this working? It could be something simple I am missing or more involved than what I think. Ideas?
