Ken Roach
I did a little test and changing this definition is easy in *.L5K text export format.
In *.L5K format the only differences between a 1794-AENT/A and -AENT/B are the Series Letter in the CatalogNumber entry and Major revision number for the firmware.
Edit the *.L5K in Windows Notepad or another text editor, then re-open the *.L5K in RSLogix 5000, which will re-create the *.ACD file (be sure to have a backup copy). This will change the definitions of your FLEX Ethernet adapter modules without tedious deletion and re-creation of all their dependent I/O module entries.
