FlexIO 1794-IB16D & 1794-IO16D Diagnostics
69FIREBIRD
Oct 2004
New Zealand
102
Hi, does anyone know how or if there is a way to turn off the diagnostics on these modules. I know you can install the resistor across the input/output but I have a hundred or so to do and was hoping that there was some config or something I can use to turn off the diagnostic function and therefore the diagnostic fault indication on the IO so we don't have to install all the resistors.
Cheers.
I sure don't think so. The Output module has configuration for Safe States, and the Input module has configuration for Input Filter, but neither one has a channel-by-channel or module-wide Diagnostic enable or disable function.
Hello everyone. I need some help on Studio 5000 (Logix 5000). I cannot add a new FlexIO module. See prints. I need to add 1x 1794OE12 1x...
1,777
what magic do i need to do to get the 1794-oe12 analog output card to give me my 4-20 ma it was configured to do. i am using a rslogix5000...
2,322
I have a 1794-ADN FlexIO DNet Adapter connected to 1747-SDN on my SLC chassis. My devicenet is working fine. All configurations are good. When...
4,679
A controllogix 5550 running a flexio on 1756-dhrio channel b; a remote rack on 1794-asb, loaded I I I 0 0 I I O, where I=1794-IB16, O=1794-OB16...
3,254
Hi, I am trying to get some flexi IO communicating. The scanner has its steady green light on The G file is all the default values.The first two...
5,227
