Flexlogix I/O Modules
There is a family of Allen-Bradley distributed modular I/O called Bulletin 1794 FLEX I/O. It has been around since the late 1990s.
There was also an Allen-Bradley Logix-family controller called FlexLogix, which used that I/O as its local I/O bus. It was never very popular and was discontinued years ago.
There is also a modern modular I/O family used with ControlLogix-family controllers called Bulletin 5094 Flex 5000.
There may also be non-Rockwell automation products that have a similar name.
Do you have a specific question about a new or existing system or module ?
Actually i have a project which we are using the Following Controller.
PLC- Rockwell Control Logix Controller with Flexlogix I/O modules.
As someone that inherited a system running on FlexLogix, my interpretation of that requirement is to use Flex IO modules.
The FlexLogix PLC neatly connected to Flex IO as a normal PLC, so the company may want to keep the same IO modules they already use on their site.
The beauty of Flex I/O is the same for many other similar products, Ethernet based + other communications so act as remote I/O to reduce machine wiring, Small footprint and can be mounted directly on terminal rail no need for wiring from I/O to terminals as the I/O block acts like terminal block.
I'm going to rephrase this question. I have a 1794-L34 controller i need to replace. Is there a better way to do this than to put in a 1769-L30ER...
676
Hi, i've write this AOI to send a ControlValue comes from pid and control a valve. this valve is controlled through analog output. the rang of...
1,032
One of our systems runs on a FlexLogix 1794-L34 processor with a 1788-ENBT for plant network access and a 1788-CNC for remote I/O. The current...
1,533
Hi guys i have a flexlogix 5434 with 1788-enbt. On the processor is a sticker with IP 10.24.230.239 but i have no idea if that's correct. I...
2,238
Hello everyone, So we have two chillers on a line, we have not used one of them in a long time. Now, it needs to be recommissioned which i...
1,914
