FlexPak 3000 DC Drive Self Tuning
JamesWSY
Jul 2005
Jakarta
81
Hi..
I am using 200 HP Flexpak3000 with field current regulator board installed. Analog DC Tacho with data 180V/1800RPM, 500 VDC and 252 Amps armature, 240 V and 3.2 Ampf of field.Top Speed is 1750 RPM, Maximum speed is 1750 RPM and minimum speed is 0 RPM.
Parameter 202 (Tach scale) is 100V/1000RPM, with HI range jumper.
I have difficulties to run self tunning of both CML and Speed Loop. Self tunning fault occur during self test. The detail fault message is incorrect tach scale. How to solve this problem? Any idea?
Thank you.
James
Two possibilities. First, are you sure you have a DC tach? It might be an AC tach with the Flex3000 doesn't handle.
Second, run the drive and motor in armature feedback mode and measure with a meter what the tach is outputting to the drive. The polarity may be backward or the scaling off.
That Flex3000 is a fine DC drive. Your problem is almost certainly not the drive's fault.
Hello everyone, We have a problem on one of our Flexpak DC drives. It was newly installed but when we commissioned it, an IET overcurrent fault...
3,550
Hello everyone another question that may seen simple but I had a brainfart after a long night of working, and I cant see to figure out the...
5,697
J
Hi.. I plant to use flexpak3000 for flywheel application. We use 150 HP, 1800RPM DC motor. Flywheel diameter is 70". Flywheel will keepturning...
2,135
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
246
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
869
