flip down cover for a 22mm PB
rpoet
Jun 2008
New York, NY
536
I'm looking for a spring loaded flip down cover for a 22mm push button. Preferably, one I can add to anyone's PB, though I'd be happy with an integrated solution as well. I need it for a shrouded enable button. Doesn't really need to be, but the client wants what the client wants. Ideas?
-rpoet
I'm not sure about spring-loaded, but we've used the Schneider Harmony padlockable flaps in the passed to restrict access to or prevent accidental actuation of 22mm push buttons. If the enclosure is vertical then the flaps will usually fall closed, but if mounted on an angled desk or console then they could be flipped open and left that way. It may not be what you're after but it's the closest I've come across...
They come in the different standard colours as well...Blue, Red, Yellow.
Regards,
George
I am having this issue trying to figure out how to do this. I have a Hydraulic ram that travels when a machine is running. The ram extends to the...
31
9,537
Hi everyone, I'm learning ladder logic and have built a flip flop circuit (see pic) from an online tutorial. Closing the switch A is meant to...
19
6,947
I found and fixed issue. B3:3 was used in MOV.
2,597
I am calculating power factor from samples of voltage and current. Calculation is done by multiplying voltage and current samples. What Im...
1,649
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,551
