Flip flop not working?
I will leave that post up as a lesson to myself.
I found the issue and fixed it, there was nothing wrong with the flip flop, there was a mov instruction about 20 rungs below that was setting B3:3/4.
Isn't there a proverb about not seeing forest through the trees?
Is B3:3/4 used anywhere else in the program?
Especially, does it have any other (U) coils?
EDIT: lol, yep, that'l do it...
B3:3 was used in MOV instruction. I had searched for B3:3/4 with no hits (beyond mine), but I did not search for B3:3. Lesson learned.
I like the code you wrote.
In the interest of learning, if you ever wanted to do a flip flop at a word level, this works pretty good. The nice thing about this one is that you can "flip/flop" multiple bits independently I.E. if you toggle bit "B9:0.0", bit "B9:1.0" will react. If you toggle bit "B9:0.4", bit "B9:1.4" will react and so on.
That's fancy and interesting. Thanks!
Mark on yours wouldn't the counter value be retentive? So you would need to be sure that whatever is happening with T4:0/DN is ok to start by itself after a reboot if it was on when plc went down.
I am having this issue trying to figure out how to do this. I have a Hydraulic ram that travels when a machine is running. The ram extends to the...
31
9,535
Hi everyone, I'm learning ladder logic and have built a flip flop circuit (see pic) from an online tutorial. Closing the switch A is meant to...
19
6,946
I am calculating power factor from samples of voltage and current. Calculation is done by multiplying voltage and current samples. What Im...
1,647
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,550
Hi Everyone, I am trying to write a flip flop circuit with one input that changes the state of two outputs. If I press the button once it brings...
3,260
