Flip Flop
Andrew EPS
Mar 2015
Brisbane
Hi Everyone,
I am trying to write a flip flop circuit with one input that changes the state of two outputs. If I press the button once it brings on output one, if I press the button again, it brings on output 2. At the moment, my circuit just changes from 1 to 2 depending on the state of the input. Can someone help me out here? I'm using a Schneider Zelio.
Like this? For third and fourth outputs.
Sounds like a standard D Flip Flop. In this case You could just make D your input, and the CLK pulse as an always on bit.
I am having this issue trying to figure out how to do this. I have a Hydraulic ram that travels when a machine is running. The ram extends to the...
31
9,545
Hi everyone, I'm learning ladder logic and have built a flip flop circuit (see pic) from an online tutorial. Closing the switch A is meant to...
19
6,948
I found and fixed issue. B3:3 was used in MOV.
2,602
I am calculating power factor from samples of voltage and current. Calculation is done by multiplying voltage and current samples. What Im...
1,652
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,554
