Float level switch
Charbel
Jan 2012
Beirut
307
dear,
i am assigning start/stop levels for the sump pump, i was wondering what is the minimum differential level that can be used when a float type level switches are used.
Is there a minimum differential level to consider?
Of course, it depends on the selected float type level switch, but appreciate if anybody encountered such issue and provide me with a datasheet of a typical float level switch.
thank you,
Charbel
The only thing you really need to consider is the number of starts per hour on the pump, you say a float switch do you mean low & high level not just a single switch ?.
If it is only a single switch without low/high switching then you will need to think about using timers on the switch so you do not hunt the pump. The type of switch you are going to use would be helpful.
As a general rule of thumb more than 10 starts an hour (on a large pump) is not recommended but will depend on it's specs.
Typical types for A = Max Starts/Hr, B = Maximum product of starts per hour times load WK2 C = Minimum rest or off time in seconds between starts
2 Pole motor
HP | A | B | C
10 |4.8 |21 |110
4 Pole Motor
HP | A | B | C
10 |9.6 |99 |55
Dear, application is for TSE water coming from a treatment plant to be used for irrigation. I will be controlling the pumps based on the level...
2,452
Hi, I have a basic sump tank with a hi level float and a lo level float. I want to control the level of this sump using a pump that is pumping...
3,258
Dear, I am working on a project that pump water out from a existing well and send it to a high level reservoir. From the high level reservoir...
3,934
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
441
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
174
