A Hydraulic Accumulator the second simplest type of accumulator. The simplest type is purely mechanical weight - the accumulator rolls/carriage(frame) is counterbalanced to provide the desired downward force (tension) on the web. If the infeed runs faster than the outfeed, the carriage moves down. Outfeed faster - moves up. Same speed - carriage holds position. The web is what physically moves the carriage.
The hydraulic accumulator is doing the same thing, except instead of counterbalancing the rolls/frame with weight, hydraulic pressure provides the counterbalance. Since you can adjust pressure, you can easily change web tension. The hydraulics also allow you to move/jog the carriage up manually.
Although position feedback is nice to have, many of these will just have three-four limit switches:
Above Full Alarm
Full
Empty
Below Empty Alarm
If it is on the infeed side of the line, you desire to keep the accumulator full except when changing rolls at the unwind (the accumulator then feeds the line while the unwind is stopped). Control for this is:
Outfeed Drive: Always runs at line speed
Infeed Drive:
If unwind is stopped, infeed is stopped
If Unwind is running, Infeed runs at high speed until Full Switch True.
If Infeed is running and Full Switch True, Infeed Speed = Outfeed Speed
