FloBoss 107 and Vortex Meters
dibdat
Sep 2022
Canada
I don't have much experience with a FloBoss107, but I was hoping someone could confirm some details for me.
I understand that out of the box a Floboss107 can handle turbine meters by accepting pulse inputs, but can it handle a 4-20mA volumetric flow signal for use in gas flow compensation?
There is some documentation that seems to state that you need to install a user program from Emerson for linear flow meters in order to utilize a 4-20mA flow signal. I've never worked on one of these before so if anyone can set me straight it would be much appreciated.
I need to be able to retrieve data from an Emerson Floboss 107. I've never done this, and it is probably the only time I'll have to. I could spend...
3,221
Hi Guys, I am going to be using a Floboss 107 and tie in a couple of turbine meters. I looked at the wiring diagram for PULSE inputs in the...
2,648
Does anyone have any experience with the DO's (the configurable ones - either AO or DO) malfunctioning? I have had at least 3 DO's blow the fuse...
2,060
How to wiring Floboss 107 DO to a relay, does it need to place a suppression diode across the load, Pls show me the wiring drawing if you know. Thanks
2,585
Does anyone know how to connect turbine meter to floboss 107 pluse input. We wired according the diagram, but i doesn't work. please help.
5,520
