FloBoss 107 DO's
Sushiholic11
Nov 2007
Vancouver
Does anyone have any experience with the DO's (the configurable ones - either AO or DO) malfunctioning? I have had at least 3 DO's blow the fuse then upon replacing the fuse the DO is not functioning. I originally thought that it was the fact that I did not have a diode across the load (coil) but even after I installed a diode the outputs continue to fail.
Ideas?
Thanks,
Sushi
what do you mean by floboss ?is it Emerson flow computer.?
If so i remember that it switches the negative and not the positive , so you should connect your load (relay for example )permanately to the +
I don't have much experience with a FloBoss107, but I was hoping someone could confirm some details for me. I understand that out of the box a...
934
I need to be able to retrieve data from an Emerson Floboss 107. I've never done this, and it is probably the only time I'll have to. I could spend...
3,223
Hi Guys, I am going to be using a Floboss 107 and tie in a couple of turbine meters. I looked at the wiring diagram for PULSE inputs in the...
2,651
How to wiring Floboss 107 DO to a relay, does it need to place a suppression diode across the load, Pls show me the wiring drawing if you know. Thanks
2,587
Does anyone know how to connect turbine meter to floboss 107 pluse input. We wired according the diagram, but i doesn't work. please help.
5,522
