Flow control valve PID tuning
ELake20
Aug 2003
N. Michigan
271
Hi guys,
Need some help.
Goal:
Closed loop flow control of valve positioner to a flow value.
Parts:
I've got a K series Rotork valve with SIPART PS2 valve positioner (I/P) that accepts a 4-20mA command.
I can send the valve a command and it responds so no problems there.
My problem is when I attempt to enter closed loop. When PV = SP the output is reduced to 4mA so the valve then closes. Once the deviation is sensed the process repeats itself.
I am using the base PID instruction for AB CLX.
Am I missing something really simple here or is this not the correct application of this?
I have considered using the PIDE instruction but I don't see what I would gain.
I have poured over the manuals and cannot seem to find any resolution. I'm sure this has come up before?
Thanks in advance
Your proportional gain may need a look too. Assuming you have some continuous flow requirement I wouldn't expect you to be able to get to the point of PV=SP without an integral term unless you proportional gain is so high that you are oscillating between (almost) full open and closed.
Keith
Check your PID equation must be : E = SP - PV.
I changed the configuration to be a derivative of Error rather than PV
edit: read the manual and will probably want to stick with Derivative of PV instead of error...
Control action
Select either E=PV-SP or E=SP-PV for the control action (.CA).
Loss of power valve defaults closed
4mA = fully closed
20mA = fully open
The 'I' term Peter suggested using did the trick. The CV no longer drops to zero so that is great.
I think the loop is still a long ways off.
The actuator is very slow, probably 30 seconds open/close. The guy who commissioned that set it up like this probably to eliminate wear/tear.
I'm thinking I want to scale the SP to something bigger. The operators are able to input 0-5, they like million gallons per day (water plant) but behind the scenes I may change it to GPM so the error amount has a little more resolution.
ELake20, did you ever settle in on a good system? I'm trying to help one our our guys in the field with a rotork on a butterfly valve and having a hard time of it.
Did you use any deadband in your system?
Sounds like our valve is much smaller than yours. We only have a 2" valve.
Thanks,
Hi! I am programming a control system using Control Logix and we have standardized on the PlantPAx Library for graphics and control. I have a...
2,122
Hello everyone I need some suggestion from you. We are controlling the flow of water in one of application. Our problem is the set point is...
4,024
Dear, I am working in selecting a flow control valve located downstream of positive displacement pump. specs is requiring that CV to be between...
3,379
Hello All Could we get some expertise on flow control ? -Using a PID loop in Productivity 2000 with an analog output, How can we convert...
19
1,594
Hello: I am experiencing the following error: [ERROR] C0297: Stack overflow detected in DecodeOID. Maximal Stack Size: 64512. Calculated...
1,223
