CODESYS Control RTE: C0297: Stack overflow detected
AlfredoQuintero
Feb 2015
Yokohama
1,551
Hello:
I am experiencing the following error:
[ERROR] C0297: Stack overflow detected in DecodeOID. Maximal Stack Size: 64512. Calculated Stack Size: 68024. Call Hierarchie:
I cannot find a clear explanation on where to increase the stack for the Control RTE soft-PLC.
If you know where to tweak, will be grateful if you let me know.
I tried building the same program in Codesys for Windowos, and it is possible to build and load without the stack overflow problem.
Is this when compiling or running?
If running, then check the logic to see whether a routine might be calling itself, either directly or indirectly.
Stack overflow is often the result of unconstrained recursion.
I am no codesys expert, but just reading through "The book of codesys" there are a bunch of provided POU's to do implicit checks on your program, might try using one or even all of these.
Quite a few available in there, and perhaps it'll help you figure it out.
Application>Add Object>POU for implicit checks
maybe it works, maybe not, worth a shot
Hello, once again, CODESYS experts. I have to setup a CODESYS RTE PLC for a customer, and I stumbled with a problem I can not solve:smas:, as per...
401
How much does it cost? I have sent several email to the US listing but never get a reply and I want to know how much the CODESYS Control RTE...
2,873
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,855
Hello. I have a system in which I have only installed the CODESYS Control Win x64 package, without the development environment. I have one issue...
2,734
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
294
