dosing 'Whole Egg & Egg powder solution'
do anything you want just don't look at the thread starting date!!
I'm not starting a new thread since its the same project that was initiated few years ago.
Just visited the Biscuit manufacturing facility yesterday.
Here's a bit of detail of what they want to be done.
They will provide us two tank filled with ingredients, one with Whole egg the other with Egg powder+water solution.
We will just pump both the whole lot to a single 'Agitator SILO'(which keeps stirring it slowly)
when needed we will will supply this mixture (whole egg + egg powder Sol.), to three final Mixers, say MIXER-1 with capacity 'X' and MIXER-2 and MIXER-3 with capacity 'Y'.
All other ingredients will be inserted in these mixers by other system (out of our scope)
however, they require us to design such a system that they will be required to change the volume of this Egg solution fed to all three of the mixers.
The feeding will be done in a closed circuit using a single pump.
Such that delivery point at a time, may be 1, 2 or 3. each controlled by a separate actuator.
The maximum feed rate is 100Kg per hour.
Some of my Major concerns, in this scenario are;
1) What if the flow meter's flow is inconsistent, possibly when all 3 delivery points are active, the delivery at the last stage may be effected. (and if there be air in this solution?)
Apparently it seems a physically operated Flow meter may not be a very good choice, can someone highlight a suitable technology considering the constant use (24hrs / 6days per week), possibility of cleaning these in-between deliveries and the product to be used?
2) design of CIP system, especially since the line will be running for 24/6. we can lay two closed circuits, one may do the CIP (clean in process) while other is feeding, but seems waste of money, I would really appreciate some assistance on the design.
3) Also what type of signal output from the Flow meters are we talking about, Analogs or digital, what pros and cons do these systems have.
Thanks and regards,
