Flowmeter with 1756-IF8 analog input
mavrick
Jun 2015
usa
122
Hello,
I have a flow meter that has been in service for a few years now. I have recently noticed that my registration on the mag meter does not match the registration on my HMI screen. When the flow meter is being used. Im seeing a fluctuation off 100 gpm. When i make the set point 600 gallons my 2 registrations match perfect. When i make the set point 1600 gallons my my 2 registrations will have a consistent 100 gallon less difference.
Would calibrating the card help fix this issue? I have verified the flow meter is good. It is a engineered card scaling 4-20 ma /0-400 gal.
Attached is a picture of the instruction that is used to add up the gallons going into the tank. The mash mag register is what accumulates total gallons and closes valves when set point is reached.
The mash IO CH6 is just the number of gpm the flow meter reads, the flow meter has no running total. Which is why there is a compute instruction used.
There is a timer dn. bit pulsing this calculation every 1000ms. So the mag register shows the accumulation in gallons to the tank.
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,291
E+H Promag P500 5069 Compact Logix implicit Ethernet IP using endress device description 30ish flowmeters, every time I download, some (but not...
1,266
Having an issue with network timing out when trying to use CIP generic on a Micrologix 1100 B. I’m trying to read flow and totalizer information...
19
5,036
Hi All, E+H Promag W 500, 5W5B1H (Ethernet I/P implicit messaging 500ms) AB 5069-L330ER v33.01* I have a customer requirement where I need to...
1,407
Hi everyone, I have been looking for a while a flowmeter for soybean oil. I have already tried wheel type and gear type with not good results...
1,025
