Force analog input in step7
smb
Jun 2003
I work on CPU314 and step7.I can force digital input and output in step7 but I couldn't force analog input.Does anyone know why?
Hi.
First, you need to know that the block FC105 "SCALE" taka a Integer value (convertion of A/D) in the input "IN" and convert into REAL Value. For example: if you have a 4 to 20 ma level meter, that have a range betwind 0 to 1000 Lts
4ma----->0Lts--------->0 INT (Input of block) Unipolar!!
12ma---->500Lts------->13824 INT
20ma---->1000Lts------>27648 INT
Now you know how to force the analog input :D I hope!!
Kind reagards
You need to be more specific in what you are trying to do...
If you are trying to write to an analog input, your value gets overwritten on every scan by the PLC. You should change your code to a temporary variable, like MWxxx, for troubleshooting.
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
136
Hi, this is my first PLC project and I need some help. The goal is to apply steady force on a random surface and for that I control a piston on...
21
7,139
Without using forceing, in the program i want to force analog value. Could anyone tell me how to do that in a Simatic S7 program. Also if there...
1,969
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
279
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
137
