Forcing in Mitsubishi, IEC Developer 6.01, Q-Series PLC
Sparki
Aug 2002
Barnsley,UK
Hi all,
weve just moved over to Mitsubishi GX IEC Developer 6.01 with the Q-Series PLC, used to have Allen Bradley SLC 500 Series & RS Logix,
my question is :
How the hell do you force an input/output in IEC Developer ?? Can someone tell me ?? :unsure:
p.s.I know how to remove a force :D
Ive spent the last two nights on my computer trying to work it out all to no avail,& the help menus are not very helpful.
Any help greatly appreciated.
Regards Sparki.
I don't have IEC version but I guess this behaviour is the same. The thing is that "force" is really a "set" or "toggle" function, not a real force like in AB world. You can force an output high or low but if the program is runing it might overwrite it if that portion of logic is scanned. You can also force an input high, but "forcing low" worked only if the phisical input was not high. Be carefull when forcing inputs unless you plan on keeping track of which one you forced or if you can afford to restart plc.
Thanks for that panic,
sometimes we have to use forces,sets,toggles etc. to get the plants running,whilst fixing the faulty field instrument thats causing the problem,or to unlatch interlocks that are causing alarms.
regards Sparki
Take a look at the reference manual (pdf file) that was installed on your computer at the same time as GX IEC Developer. If you search for the word "Force" you should be able to find some details of forcing inputs.
As Panic Mode stated previously, Mitsubshi doesn't have forces in the AB sense. I used to program AB and then changed to Mitsubishi. When I started using Mitsubishi I was concerned about the lack of a force function. But soon I got used to life with out the force and have found alternative means to keep a machine running or test a program.
Dear Fellows; I am working on a very old machine which is designed in GE 90-30 PLC system. I have some difficulties like 1. How a force to...
352
Hi. This is the first time I do a project with Rockwell PLC from scratch. I started a bit just building some AOI for a couple things I need to...
576
Hello, when trying to force two outputs nothing happened. The text ON appeared by the adress. It was also possible to force off, which also...
17
4,809
In GX developer, is there a way of forcing a digital input to ON (e.g. X070 to TRUE/On). I've just installed a QX10 module and I want to check...
4,883
Hello, Controllogix 5572 with Studio 5000 v33 and FactoryTalk View SE v12. Is there a way to force I/O bits using HMI pushbuttons? I've tried...
2,899
