GE 90-30 Forcing Bits
turbohamad
Jun 2009
Multan
108
Dear Fellows;
I am working on a very old machine which is designed in GE 90-30 PLC system.
I have some difficulties like
1. How a force to discrete input and output device like switches or solonied etc? can i also force the %M?
2. How i know that programmer use the maximum %R or %M address because i need some modification and use the %R and %M which is not using before?
3. How i over ride the %AI and % AQ to check the values before start, Suppose %AQ is 0-32000 counts for 0-50 mA. I want to check by applying 10000 to %AQ to check the behavior before start.
Regards
Forcing is a two-step process. The first step is to force the point. The second step is to toggle between the on or off states. The details of how to do it depend on the software you're using to monitor the action.
Yes
When you enter a new instruction, type the address designator only, without the numeric part (%M instead of %M0123). The software will select the next available address in that data type. Works for Logicmaster, VersaPro and PME.
You can't force analog inputs or outputs.
Thanks steve;
I am using LM 90 software, how i force the %I or %Q or %M?
In LM 90 it means i am not able to write counts to %R where %AQ or %AI data move?
For example a transmitter 4-20 mA = 0-32000 counts and this data move to %R0001 if i want to check by passing 16000 to %R0001 after the move instruction is it possible?
Regards
You must be online and in "Logic Equal" state. Move the cursor to the bit you want to force. F11 will turn on forcing for that address. F12 will toggle between states. Remember that once forced, a bit is no longer under control of the program, so be sure to cancel the force by hitting F11 again once you no longer need to force the bit.
You can write to any of those addresses, but if the ladder logic also writes to them it will take precedence over what you try to write. The techniques for forcing that I described ablove do not apply to %R. %AI, or %AQ.
You can enter a new rung of logic to do that, but if you position the cursor over the address and write a different value to it that value will only be active for a single program scan.
Control logix5000. If have an XIC on a rung with an OTE I can force the OTE on but if I force the XIC it doesn't turn on the OTE. Why is that...
26
6,770
Gentlemen. I'm having trouble forcing a bit on in my logix5000 program. I see its not as easy as it is in the 500 program. When online the drop...
39
11,786
Hi, I haven't used Unity for a while and have just fired it up to develop a good sized program. At first glance it seems that I can only force...
9,340
Hi. This is the first time I do a project with Rockwell PLC from scratch. I started a bit just building some AOI for a couple things I need to...
576
Hello, when trying to force two outputs nothing happened. The text ON appeared by the adress. It was also possible to force off, which also...
17
4,808
