Forgot to ask, RS500 program making ladders
More specifically, in the project tree (left pane) right click on "Program Files" and click "New...". You'll be prompted for a file number, name, and description. This cannot be done online.
You also need to add rungs with JSR instuctions that call the additional program files in file #2. File 2 is the only file the PLC will scan without being called by a JSR.
The ML1000 comes with 16 predefined ladder files. You cannot add more and you cannot delete them. Ladder 3 is reserved for the fault routine, 4 for the high speed counter interrupt routine, and 5 for the selectable timed interrupt routine (though if you dont use the HSC or STI you can use them for something else) and 16 is reserved for a debug routine. You also cannot change the data files or enlarge them.
I try to stay away from the ML1000 - The ML1200 is only a few bucks more and well worth it for the functionality.
As an aside to this has anyone ever come across a programm to actually make ladders. The type you use to climb I mean. Just interested if there is a ladder ladder program out there. Regards Alan
It was one of those days. Happy to get a new laptop. Got all my PLC and HMI code moved over, new Rockwell installs, licences moved, the whole bit...
2,434
I had to get a new thumb drive for all of my Rockwell Software, (PV+ and RsLogix.) Do I have to create a Rockwell Software folder or will it do...
2,232
Good Morning , I upgraded a Machine to a CompactLogix ( from a SLC 500), but I never knew that the SLC that I replaced communicated with a...
2,489
hello I have a project that contains a program with a RX3I controller (IC695CPE305), And I protect this project with a password but I have to...
3,550
Hi! It was at least 15 years since I done a project with a Siemens S5. Now I have to make some minor changes (timers etc) on someone else's old...
2,800
