FP-X C60R Panasonic PLC Reprogramming.
hinddhindsa
Mar 2013
www.plckart.com
193
I have FP WIN PRO and FP WIN GR Panasonic programming software, i have been trying to reprogram the FP-XC60R PLC from the back up program which i received from machine supplier. when i try to open .pro file throught FP WIN PRO SOftware i get error, 'file does not exist'.
Please help me. what can be the reason and is it the correct software i am using ?.
Panasonic PLCs programming
Hi ,
Extn for WPwin pro programs is .pro , so it should open your program . There may be issue with correct version .
I had similar issue here ,I uploaded a program from FP sigma PLC in FPwin , on saving it saves with extn .pro ,there is another file created same filename with extn .ini . This running program in PLC fails to Compile . I finaly used Win GR for online operations.
It is hard to get Panasonic expertise the way we easily get it for AB , Siemens or Schneider .
Good Luck
hi
when i try to use FR WIN GR software demo version,
i am not able to view or access any of the file .pro , .mtp , .xob , .Idt file which are program back up.
so tried through fpwinpro, but with tht file is not opening wht should i now
having the demo version only allows you to have 1000 points in a program so might not open a 3000 point program.
mate you have been on this site for a while
please post the zipped copy of your program
FPwin Pro
It seems , getting the .ini file alongwith .pro file will solve your problem .
You need full version software for larger files , demo not sufficient .
hi everyone. i'm working now with panasonic PLC. The machine is OE, so I uploaded the file using FPWIN Pro 7 but when I open the program and try...
660
I am involved with the Panasonic FP7 for my final year project. I am doing a water distribution system and I want to use interrupt program for the...
730
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,739
I'm working with a Customer that has 2 Panasonic FP2-C2 units. I'm not exactly sure what this even is... Is it a PLC with motion control or just...
1,550
Currently working on a job for panasonic using FP-XH model PLC. I have finished my code and it seems to be working as expected (hopefully) :utoh...
1,766
