Frequency measurement methods. PLL?
I use a zero crossing detector circuit which turns 1-120VAC sine wave in to a 24VDC square wave. Square wave goes to the PLC high speed counter input.
This is much better than using a frequency transducer with 4-20mA input as the resolution is determined by the clock in the high speed counter.
I would be interested in seeing suggestions for products which provide this sine to square wave zero-crossing detector functionality as the one we are using is an artisinal product and I don't know what we will do what the artisan retires.
Whats the EL3413 sample speed
Found this from documentation (link):
"The default setting
for the measuring interval is 10 periods (10 x 20 ms). Experience shows that this is a good compromise
between measuring speed and stability. Deviations from this value are only advisable in the event of
particular measurement requirements (e.g. high measuring speed)
Hello,
I have to say thank you all for a lot of help. By reading here and searchig on google and reading again I have simulate PLL method on matlab trial version in discrete mode.
All is working fine. What I mean, it is possible to get correct frequency more than 200ms for sure. It depends about assumed value and of cource PI settings.
Now I would like to get some ideas for Filter, for example If I want to avoid
3rd harmonics, actually I am interedted only on frequencies between 45-55Hz.
When I simulate now noise(3rd harmonic with 5% of my amplitude) my measurements gets wrong.
Do you guys have some ideas how to filter frequencies above some range lets say.
I'm reading someone else manual inside which is described speed measuremnt by measuring the time in between 2 signals. It says "The 24VDC...
2,624
Hi - off topic but hopefully someone has some experience. I am looking to install a level detection unit for monitoring fill levels in bottles...
1,919
Hi, I have an application where I need to measure the speed of a rotating roll on a Siemens S7-400 system. I have an incremental encoder connected...
5,852
2,975
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
408
