OT: High Frequency Capacitance for level measurement
Freak
Oct 2006
Barossa Valley
195
Hi - off topic but hopefully someone has some experience.
I am looking to install a level detection unit for monitoring fill levels in bottles. The catch is that I need to monitor at a 30mm fill height with a 60mm metal screw cap on the bottle (so the fill height is covered by the screw cap).
We currently use Xray units that detect the level using density. I am needing to repair a unit and have been advised that it is possible to use High Frequency Capacitance to do this. I am having a hard time getting my head around the concept of it working with the metal screw cap covering the product.
Has anyone had experience with this? The unit that I am being offered is made a LogiLevel by Logics & Controls.
Cheers
Peter
Capacitance is a charge between 2 plates. The top plate is floating above the bottle. The bottom plate is the ground plane below the bottle. Think of it as a measurement of the total air volume between the 2 plates. The liquid will take up part of this space. The cap isn't connected to one of the plates, so it will be ignored.
It's more complex than that, especially if the liquid is conductive, but this is an easy way to think of it.
Edit: The liquid must be conductive for this to work. Humidity and temperature are factors, but it looks like they deal with this.
Hi!
Wouldn't weighing be simpler? Or are there speed issues or something?
Thanks Keith- makes sense now.
Boneless - the issue with using weight is speed (450 bph) combined with the variability in glass weight.
Cheers
Peter
Looking for suggestions on a pathway for a high speed, variable frequency output for a slitter line. There is a corporate data collection system...
1,695
Hi everyone,:cool: I have been facing the problem of encoder (1024 ppr) not reaching to its desired position while in auto mode. The PLC fault...
2,077
I have a problem with an induction furnace heat treatment makes it a car part, it does generate heat through high frequency induction that...
1,505
Hi friends; I use a APU 300 frequency module. Configured as TYPE A counter. The application as under Magnetic pickup signal came into the...
2,030
Induction sensors with high temp rating (100 degC) & high switching frequency(<5KHz)? Hello all, I am trying to get some tubular/barrel M12...
2,324
