Induction sensors with high temp rating (100 degC) & high switching frequency(<5KHz)?
matt_sd
Jan 2007
Australia
96
Hello all,
I am trying to get some tubular/barrel M12 sensors for a hydraulic gearbox. Anyone know any supplier that does M12 induction sensor with minimum 100 degrees C temperature and <5KHz switching frequency?
I have spent a few hours looking, they are either the higher frequency or higher temperature.
Thanks Matt
I ended up finding some - I searched for Hall effect rather than Inductive sensor.
The Hall effect sensors are rated at higher switching frequency
Is there any issue with running a VFD-controlled 3-phase induction motor in torque control mode in the braking region continuously (back-driven by...
4,039
Hello everyone! I'm new here and this will be my first post so hopefully I can get some help, I'm having a hard time wrapping my head making some...
4,797
Why it is said Maximum torque of induction motor is inversely proportional to frequency square ? Maximum torque formula for induction motor is...
4,522
I have an auger powered by an induction motor under flux vector torque control driven by a PowerFlex755. According to my log, the command velocity...
5,075
As you know there are three region for induction motor's operating. What I'd like to ask if motor is regenerating energy during plugging which...
1,556
