Frequency meter in PLC
Favian
Aug 2005
17
Hello, Im trying to measure the frequency (Hz) of a fast input.
what Im doing now is copying the Acc Count twice a second apart and
subtracting. This seems to work but it takes 2 seconds to update the frequency value which may or maynot be ok. Is there a better way of doing this? thanks.
Why not try a converter. Companies like Endress and Hauser do digital to frequency signal converters where you get a 0-10V or 4-20mA signal to feed into your PLC.
So how fast a frequency are you talking about.
I assume you are trying to calculate a value that updates continuously. Create two registers, current_count and prev_count. Once every second, copy current_count to prev_count, move the accumulated value of the counter into current_count, and subtract prev_count from current_count to get the current freq.
If you do it this way, you'll be updating every second instead of every 2 seconds. If that still isn't fast enough, how about updating every 500ms and multiplying the result by 2?
hello i am trying to set the max frequency for the drive via rslogix 5000, but do not see that patameter in the rslogix 5000 drive paramerts? the...
323
Hello, please its possible to control flow rate using frequency mode of a flow meter ? if yes, how is it done for a PLC like Micrologix ? i...
2,224
Do you folks know of any Motor Frequency Meters that have a 4-20 ma output ? I know a frequency drive would provide that need , but the customer...
2,507
I need a frequency meter that can do the following Be able to hook directly to 0 to 120 VAC Able to measure from 0 to 120 Hz. Here are two...
3,522
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
413
