FSGateway/RSLINX Question: Can It Read PLC-5 format?
Colt Hero
Apr 2015
USA - Southeast (but from Northeast)
109
We've got (2) Wonderware apps here that read the same set of Rockwell PLCs. One was built a long time ago, and the other came along much later as part of another project.
The one that works (older one) appears to be reading some of its data using FSGateway with Topic Names prefixed with "RSLINX" and SuiteLink Protocol ... even though the old PLC-5's it previously read were upgraded to ControlLogix PLCs.
There are also some Topics using ABCIP which read other, newer ControlLogix PLCs.
QUESTION: Can FSGateway/SuiteLink read ControlLogix PLCs using the old PLC-5 tagname format ... because I can see cases where this appears to be happening??
The reason I ask is the newer app has never completely worked. Only the ABCIP points are updating. I've verified this machine can PING all the PLCs in question, and that the IP Addresses and Device Name/Topics are correct in SMC, but it doesn't make sense to convert all of its tags over to ABCIP if the old application works. Maybe the faster thing to do is install FSGateway and SuiteLink on the new machine??? And what would be involved there? Where does RSLINX store its tag list ... or does it?
Friends as the heading shows i want to integrate rslogix 500 with rsemulate 500 and rslinx opc server with fsgateway to see data in intouch...
2,113
We have Wonderware 2012 all set up (been set for years) using a server in the SMC console this can be seen as DASAPPLICON to talk to an S7-400...
1,051
I tried doing this by adding a remote opc server running wonder ware on an Opto22 controler using ethernet. The topic comes through and is active...
2,130
hi, I am currently working on a project that requires access to the data inside plc using Codesys OPC server v2.3 and I want the data to be...
3,026
Hi, I am designing a control system using Allen-Bradley ControlLogix PLC with Wonderware Intouch as the HMI. I have done this before using...
3,517
