FT Historian Start stop logging
RSDove
Aug 2012
melbourne
I have a FT Historian system up and running for some time now and it works fine, but I would really like to know if there is a way in PI to start and stop logging based on a tag value? Any help would be great.
I don't think what you are asking is possible. There may be a way to turn scan on/off via a VB script, but it takes around 180 seconds for a tag to be placed in the que, and sent to the server. With hard drive space so cheap these days, why not log all the time. It's what we do.
If you have your tag configuration set correctly it will not collect data very often if the tag value does not change.
Thanks for the reply, I kind of figured that was the case, I just wanted to clean things up a bit and logging 100 pts every 100ms just seems silly when the machine only runs 4 hours out of 24 lol.
Take a look at your tag "tuning". When the machine is not running, you should only get a new value every 8 hours or so. Do you have the PI builder add-in for Excel? If you do export all the tags to Excel, review/adjust deltas etc.. and import back in.
Also in PI System Management Tools (SMT), you can go to the data area and use the Archive editor to see how many values are actually being recorded.
I noticed that the new FTHistorian 9 only uses the PI 2018 still, and is not updated to 2023 yet. I figured by now any new releases would have...
193
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
148
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
Hello Everyone, I want to install and configure factorytalk Historian v6. I'm new to this. Can you kindly share some knowledge on installing...
87
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
191
