FT View SE V10- VBA Set Object Focus
Tanquen
Jul 2014
CA
163
Is there a way to set a clicked object to have focus.
I'm trying to open a popup next to where I clicked and "Display popup /RP /T" with the "/RP" options works but it’s always one object behind. So it opens the popup next to the last object clicked. I'm sure it’s because I'm using the Display command in VBA so there must be a way to set focus to the object and then run the Display command.
I tried the Set Focus dot field but only certain objects like buttons have it.
It seems like there should be a way to get this but I was able to grab the objects X/Y position for the popup and use that vs. the mouse position with the display command.
So:
became
Display popup /X Object.Left /Y Object.Top /T
I have some code that is working but only if linked to mouse button 1 and I really need it to be a button 2 or right mouse click function. The...
9,540
I'm trying to write to an objects .Value based on a different value for the objects number. So if the object number is 1 then...
3,552
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,221
Hey all, First post! I am trying to embed a web browser into my application to enable us to watch live feed of our AXIS IP Camera. The problem is...
925
I have a FT View ME project that we need to make a simple change to and all we have is the .mer file. I tried to restore it with the application...
1,078
