DamianInRochester
As an example, if i create a tag in the PLC called "tag1" as a DINT, and then reference several times that tag at the bit level in FTalk, does the PV sample the entire tag everytime I look at a bit, or does it recognize that it already has the entire DINT.
To put it differently, if I have indicators on a screen with connections referenced as follows
{::[L35E]Program:Test.tag1.0}
{::[L35E]Program:Test.tag1.1}
{::[L35E]Program:Test.tag1.2}
{::[L35E]Program:Test.tag1.3}
{::[L35E]Program:Test.tag1.4}
{::[L35E]Program:Test.tag1.5}
Is the PVP "wise enough" to recognize that is already has
{::[L35E]Program:Test.tag1} and doesn't need to call for it everytime I want to look at a bit in it?
