Different audio alarm based on alarm priority in FTalk View SE?
harryting
May 2002
Puget Sound
2,595
Most HMI have the ability to sound speaker on alarms. What I'm wondering is does Factorytalk View SE have the ability to use different audio clip based on alarm priority? I know there are probably always a way with VBA but I rather keep it simple and use built-in setting instead.
Bump, thinking about it this morning I may not be able to change the audio beep for a PC but I should be able to trigger different physical output based on alarm priority, right?
I'm not very familiar with FTView SE's alarm management. So anyone knows the quickest way to accomplish this?
I did the audio thing on a recent project, so yes....possible. I don't have access to it right now, but my recollection is it's in the global settings of the Alarm & Events server setup. If you are using an older version with HMI Tag-based alarming, then VBA is *probably* necessary and the Rockwell Knowledgebase is your best resource.
The physical output thing is also possible using, as I recall, A&E functions driving Derived Tag values that are sent down to your PLC. VBA applies if using HMI Tag-based alarming.
Hope that gives you something to run with.
116
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
75
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
393
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
687
