I've recently set up a Factory Talk Activation Manager server and I'm starting to migrate Rockwell licenses to it.
Twice now I've had the problem where a Floating license has locked up "In Use" after use. I'm pretty sure the cause is disconnecting from the network while the license is in use.
So far I've tried...
- Installing matching version of FTAM 3.62.11
- Rebooting PC, Re opening Logix 5k (Of which still runs of the same license) closing and refreshing server
- Refreshing at server and PC
- Removing License from server and adding it again
- Following Knowledgebase:55028 and trying to fine the relevant license RS5K_600.EXE file in task manager and close it. Its nowhere to be seen
The first time this happened, later in the day it randomly corrected it self. Does anyone have any ideas?
Cheers.
Cheers.
