FTV Alarm Import Errors
tduke02
Oct 2016
Salt Lake City
Hello All,
This is my first post, so bare with me.
I am working on setting up a new alarm server on FT SE. I have already added a few alarms but used the export tool to Excel. Added about seventy alarms using the same format as the other alarms. I then used the import tool and everything went well. I exported again and added about fifty more alarms and when I try to import back into SE I get the following error:
Unable to load the XML file: Mixers_Lqd_Pack_Lqd_Pack_AES_AlarmExport.xls
Cause: minLength constraint failed.
The attribute: 'name' has an invalid value according to its data type.
Line number: 3570
Character position = 76
<FTAlarmElement name="" latched="" ackRequired="" style="Discrete">
This status file 'AlarmImportErrors.txt' can be found at ''
I can also add these in SE one at a time but doing them as a batch was so much faster.
If anyone has any ideas it would be appreciated.
Thanks,
Tim
So, something in the last added data has a problem. And the error is pointing to the location of the offending element. Are you using VBA code to create the new data? Maybe you're creating a name or path too long.
No. I'm not using vba, just digital tags to trigger an event. Since I couldn't get the second import to work, I exported what I already had because I knew it worked and then copied the remaining alarms from the old excel file and tried to import again. Everything worked without an error. I must have "fat fingered" something on the one before.
Thank you for the quick response.
Hello all. I am working on a project that i was lucky enough to copy from another machine. The other machines device shortcut was [plc] so all the...
2,440
How would I got about setting up the alarm and event log viewer to only show alarms? i.e. I want to get rid of all the quality, enabled, disabled...
872
Title pretty much says it all. Just when you think you've hit every FTView landmine, bam. Using V10 SE Local Station. When I create a Tag Alarm...
7,124
Hi guys i'm newbe to FTV Studio and so i ask again your help! Two questions; the first: on plc i have an array for the alarms messages tag name =...
2,100
Morning I have created an alarm list in FTV ME, this time i used DINTs to bank certain alarm together such as individual tank alarms or system...
1,949
