FTV Studio alarm import/export
dginbuffalo
Dec 2010
Buffalo,NY
630
Hello all. I am working on a project that i was lucky enough to copy from another machine. The other machines device shortcut was [plc] so all the tags and alarm triggers reference this. My project is [Machine#]. The export alarm tags is an xml file. how do i modify this and re-import it? I'm assuming excel but not exactly sure the formats to open and save in. Thanks for any advice!
For the application Displays' and Global Objects tags use the Find/Replace FTVS tools (Menu Bar/Tools or Toolbar).
For the Alarms, right-click the Alarms/Alarm Setup Project Tree folder and then choose Import and Export.../Export.
Edit the .xml file with Notepad using the Edit Menu Find/Replace tools.
Import into the new application when done.
Hi guys i'm newbe to FTV Studio and so i ask again your help! Two questions; the first: on plc i have an array for the alarms messages tag name =...
2,100
I have a problem with ME... I got all my alarms right..everything went well when I trigger them... the problem is that the "alarm time" &...
21
6,324
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
134
Hi all, I have FTV v13 installed on my VM. I made an ME application and exported it in v11, as that's the version being used on the Panelviews at...
407
Hello Friends, I want to log FTV Studio SE alarms and event data into a oracle 12c database and as i checked the by default windows in FTAE...
825
