FTV Global Objects
dginbuffalo
Dec 2010
Buffalo,NY
630
Hello. I'm starting to use Global objects that are grouped with several different parameters. In some circumstances I want to change a global object by adding something to it. When I do this, it wants to erase all the links associated with the object. Is there another way to add to the global object and accept the new grouping without losing all the link data? Thanks in advance.
PS- Chris makes sum hella lugnutz! (Inside joke to a friend who frequents this site :p )
Once you ungroup it, it breaks all the links. You'll need to copy into the group any modifications. That is open the group and then paste objects so they become part of the existing group.
I believe the links are maintained from the global object group name. I just note down the Group Name from the property panel before ungrouping and then when i regroup it i just make sure it has the same Group name, if it's not you just change it to the original name.
But i think from memory all the link definitions will be lost.
Hello guys i have a question about resizing of global objects in FactoryTalkView Studio (8.2). I want to resize objects linked to global...
21
9,200
Hello, I'm having an issue that I did not expect to run into. Using FTV SE v11.0 (CPR 9 SR11) I've created and saved a global object inside the...
1,516
Hello, I have a global object for a button set up with two parameters. One that is the "control tag" for the button and the other that is the...
2,171
Hi, I'm currently developing an HMI on FactoryTalk View Studio v12. It seems that global object instances will randomly lose their link to the...
2,038
I have a bunch of devices on my displays that are the same. I have build a global object for them and is working great. I want to place a button...
1,954
