FTV ME Client Runtime Target?
Gabe1
Nov 2015
Alberta
Hello All,
I'm hoping someone can shed a little light on FTV ME runtime comms configuration for me.
I've got a FTV ME client (PanelView 1500) running FTV ME station version 7.0.
It's currently using a local network connection (EN2T module we're using for local VFD's, flex rack's and this HMI) to speak with a single 1756-L72 controller (Ver 24.) The programming workstation is on a separate PLC network that communicates to dozens of racks around the plant.
I've made a few changes to the runtime using FTV Studio Version 8 (MER saved as Ver 7) but cant seem to get the HMI, with updated MER, to communicate to the PLC. I. I can test the runtime in FTV Studio but I get a series of "unresolved in the processor on route..." error messages and no data on the HMI.
I figure it has something to do with the Runtime target setup in the "Communications setup" config window. It's setup the same as the design target. I think such a config would work if the PanelView was on the PLC network rather than a device level network that uses a separate ethernet card.
Maybe the PanelView network configuration could be responsible? I assumed I wouldn't have to change anything there.
Thanks for your commments.
Hi Everybody, I am having a problem when I start the SE Client(Local Station), it pops up the loading windows but disappear after a while. I...
1,779
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
106
Hello people... Quick question. With a network distributed FTV SE system, do FTV SE clients have to run the same version of FTV as the FTV SE HMI...
2,454
I am developing FTV SE Network Distribution application. There are 1 x server and 3 x client in a control system architecture. When I login at...
4,479
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
134
