Ftv vba issue
Rahul3005
Dec 2017
Mumbai
34
Dear SIR ,
We are having some problem regarding VBA code for FTV 8.10.
We had a project in which we had to convert the old SCADA RSVIEW 32 with the latest FTV.
In old RSVIEW32 , recipe functionality and some functions in SCADA were written in VBA code , we converted the old RSVIEW 32 with the new FTV 11.0 , but after successful conversion and after legacy tag database conversion , some display of SCADA application had active x control , after opening that particular display , there was an error popup “ Unable to load ActiveX control for ‘display name’”.
We restored the application for a lower version of FTV (v8.10) , after restoring the application in FTV (v8.10) , the following issue was resolved.
Now coming back to main issue which we are currently facing , since the FTV have a client based VBA functionality and the old RSVIEW 32 had a server based VBA functionality , we converted the entire VBA code with respect to our new FTV application , after conversion of VBA code , some function of recipe are working OK , function like opening an already created recipe , viewing the selected recipe etc.
EXPECTED RESULT : There’s one function in SCADA application “creating a reciepe” , after creating a particular recipe , recipe editor screen open properly as expected , and the “segment 1” column is editable , after operator pushes “AUTOPURGE” button on recipe editor screen , “segment 1” column should automatically go up , the “segment 2” column should be in middle , “segment 3” appears at downside.
Now as you can see video 1 , when normally the auto purge command is issued from runtime , the expected VBA code is executed , but the expected result is not achieved , as you can see in video 1 , the “segment 1“ is not changed and it stays in the same position as it was before .
Now as you can see video 2 , now before issuing the auto purge command , I manually brake the vba code at the start , that mean when i press “auto purge” command , the vba code will not execute completely , but it will stop at that position , where I have applied brake. (red dot is a brake) , then after issuing ‘auto purge’ command from runtime , I open the VBA editor screen and I manually execute the VBA function using “step into – F8” function in VBA editor and run the entire vba code manually.
After the entire code is executed , we can see that the “segment 1” row has shifted up , “segment 2” row is in middle and “segment 3” has appeared down.
What maybe the reason of this discrepancy ? when I automatically execute the VBA code from runtime , it doesn’t work , but when I manually execute the code from VBA editor , it works properly.
Link for video 1 - https://drive.google.com/file/d/1M1DmOdc7_7HxJfGDyJtddWmI27EXgH14/view?usp=sharing
Link for video 2 - https://drive.google.com/file/d/1M0qvCMgzbCCPANI6Xamzv5hi32FNSZit/view?usp=sharing
:rolleyes:
Anybody know of a complete (or relatively complete) resource for VBA functions available to FTV SE? I know there are specific functions and...
1,613
Can you help me with the following? I know when creating an expression using the "display" command I can use different switches to cause the...
1,025
I’m trying to disable a button after a popup is opened using VBA. It works and the button looks disabled but I can keep clicking the button until...
2,194
I am using factory talk view se. I am trying to find a way to open a display automatically at the same time each day. I have tried using VBA code...
1,845
