FTView Graphics suggestions
mister x
Jan 2019
Canada
156
What are peeps using for outside graphics editors for FTView? I threw together a gauge with Inkscape that looked pretty good. But to get it into FTV and keep the separate elements for animation, I used the import .wmf feature of symbol factory - it did not go well.
I could bring in the gauge background with a .png/.bmp import and then animate a needle over the top, but that's pretty crude. Any success stories out there?
I use Adobe Illustrator CS6 and save all of my graphics in a .PNG file format. You want to make sure that you save the .PNG as the exact size you want it to be pixel wise in your FTVS project because that produces the best image. If you export it from AI in say 100x100 pixels and then resize it to 200x200 it will look like ****, and conversely if you downsize it to 50x50 is also looks like ****.
I can see the attraction of Ignition in this regard if it actually takes .svg files without mangling them. I'll have to try it later. The Symbol Factory Rockwell still uses in FTView is an old revision. Version 3.0 doesn't even process .wmf anymore...
FTView SE 8.2 Distributed environment I'm modifying some graphics on a couple HMI servers that sit on different physical machines. When trying...
1,430
Hi All Working on a site developing a HMI project for a PV+ 1250, as well as a FTView SE Scada project. using FTView studio V7 for both. Have...
6,911
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
87
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
42
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
196
