FTView "Out of Service" error when saving graphics
phuz
Jun 2008
Mohnton, PA
1,044
FTView SE 8.2 Distributed environment
I'm modifying some graphics on a couple HMI servers that sit on different physical machines. When trying to save the graphic, I get the error:
The server 'HMIServerName' in area 'RNA://$Global/ApplicationName/AreaName' is out of service.
I found this TechNote which talks about file permissions, but the permissions are OK, and I changed the Logon time to 0, as the note suggests.
And just as the note mentions, a file containing a bunch of arbitrary characters is generated instead of saving the original file.
For example, header.gfx doesn't get saved, but header_new_27bb6e4d-5c27-4aef-bb13-ce28948fbee6 gets created.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/40564
WAG - Can you reboot those servers? When I worked with FT a reboot could solves some issues.
I've rebooted the HMI servers, but not the directory, but I just now rebooted the directory and still getting the same error.
Here's the fix:
Go into your Program Files / Rockwell Software / RSView Enterprise and double click RSViewWebManager.exe.
Something to do with re-syncing users for IIS.
Working on a customer's FTView SE Distributed (v11) environment, and I am using one of the workstations for development. I have been getting a...
1,442
I have recently learned that Rockwell Software's FactoryTalk View SE version 6.x doesn't function well with the Windows 7 Tablet PC Input Service...
6,419
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
220
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
