FTView SE and Tablet PC Input Service
mlmeng16
Dec 2010
Michigan
I have recently learned that Rockwell Software's FactoryTalk View SE version 6.x doesn't function well with the Windows 7 Tablet PC Input Service. My PC is a touchscreen computer. In order for the FactoryTalk View SE to run, the Tablet PC Input Service was disabled.
The PC is running Windows 7 Professional Service Pack 1 (32-bit). The processor is an I-Core i5-2520M (2.50 Ghz) with 4.00 GB of RAM.
FactoryTalk View SE is version 6.00.00 (CPR9 SR3) Patch/Pack Number: 00 Build Number: 16
Is anyone aware of any "work-arounds" to allow a touch screen PC to run FactoryTalk View SE?
I'm using windows terminal services to run HMI clients on IPads here. I have 2 windows server 2008 vm's for terminal services so you can open a FTView client from any PC with remote desktop or any device with with an RDP app, IPad, Android etc.
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
218
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
90
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
254
